Re: 37E???
This is a fuel temperature to high could be the fuel temperature to high, sender or harness. FUEL TEMPERATURE CIRCUIT IS DERATING DUE TO A FAILURE IN THE SENSOR OR HARNESS, OR THE FUEL IS REACHING A TEMPERATURE THAT CAUSES DERATE TO OCCUR. FAILURE IS NOT A COMPLETE OPEN OR SHORT THAT WOULD CAUSE A 37E OR 38E ERROR CODE.
Solution Number: 6111
Solution Summary: SIB-97-5-25-09 AUG 22 1997 ERROR CODE 37E OR 38E IS DISPLAYED ON THE TACHOMETER / MAY HAVE LOW POWER------9500, SideHill 9500,CTS and 9600 Combines
Publication Date: Mar 21 2007
**Paper copies of solutions may not be the most current solutions**
Complaint or Symptom :
ERROR CODE 37E OR 38E IS DISPLAYED ON THE TACHOMETER. LOW ENGINE POWER MAY ACCOMPANY THESE ERROR CODES.
REFER TO PIP 97H-153 THAT CORRECTED THE CONNECTOR PROBLEM ON 9600 COMBINES.
Problem or Situation :
CONNECTOR (A) COULD BE LOOSE.
WIRING TO CONNECTOR (A) COULD BE DAMAGED.
FUEL TEMPERATURE SENSOR COULD BE FAILED.
Solution :
1.) VERIFY THE CONNECTOR IS TIGHT BY CHECKING THE AMOUNT OF MOVEMENT IN THE COUPLING PLASTIC RING (A). IF THERE IS NO MOVEMENT, THE CONNECTOR IS TIGHT. IF THERE IS MOVEMENT, GO TO STEP 2.
2.) LOOSEN AND REMOVE THE FUEL SENSOR CONNECTOR. REMOVE SCREWS (B & C) AND CLAMP. REMOVE SCREW (D) FROM CONNECTOR BODY. HOLDING INSIDE CONNECTOR (E) (UNDER SILVER RING), TURN CONNECTOR HOUSING.
NOTE: MAKE SURE YOU HOLD THE INSIDE OF CONNECTOR (E) AND TURN THE TOP OF THE CONNECTOR TO GUARD AGAINST THE WIRES TWISTING.
3.) SEPARATE TOP OF CONNECTOR (F) FROM THE BOTTOM CONNECTOR.
4.) PULL UP THE GASKET AND RUBBER SEAL (G). CHECK FOR BURNT OR TWISTED WIRES (H). IF THERE IS NO DAMAGE, REASSEMBLE THE CONNECTOR.
NOTE: MAKE SURE YOU HOLD THE INSIDE OF THE CONNECTOR AND TURN THE TOP OF THE CONNECTOR TO GUARD AGAINST THE WIRES TWISTING.
IF THERE IS ANY DAMAGE, ORDER AH157803 AND INSTALL THE KIT USING THE FOLLOWING INSTRUCTIONS.
A.) REMOVE THE CORRUGATED CONDUIT FROM THE WIRE HARNESS AND IDENTIFY THE WIRES CODED 128 AND 130. REMOVE THE OLD CONNECTOR, INSTALL HEAT SHRINK TUBING (1) OVER THE WIRES, AND SOLDER THE NEW CONNECTOR ONTO THE HARNESS. MAKE CERTAIN THE WIRE CODES MATCH.
IMPORTANT: WHEN REMOVING THE OLD CONNECTOR, CUT ONE WIRE 35 MM (1-IN.) LONGER. THE EXTRA LENGTH WILL PROVIDE ADDITIONAL STRENGTH IN THE HARNESS.
B.) WRAP THE REPAIRED HARNESS WITH ELECTRICAL TAPE STARTING AT THE CONNECTOR AND CONTINUE 50 MM (2 IN) PAST THE SOLDER JOINT.
C.) INSERT THE WIRE INTO THE CORRUGATED CONDUIT. TAPE THE CONDUIT BY STARTING AT THE CONNECTOR END. APPLY TWO FULL WRAPS OF TAPE ON THE WIRES BEFORE TAPING THE CONDUIT. CONTINUE TO TAPE THE CONDUIT 25 MM (1-IN) PAST THE BREAKOUT FOR THE FUEL SHUT-OFF SOLENOID.
D.) CLEAN THE FUEL SENSOR CONTACTS AND APPLY A LIGHT COAT OF OIL ON THE O-RING (L). INSTALL THE CONNECTOR ASSEMBLY AND TIGHTEN THE METAL RETAINING NUT (K) UNTIL THERE IS NO MOVEMENT IN THE PLASTIC CONNECTOR (J).
+ YOU MUST USE A LUBRICANT ON THE O-RING OR THE METAL RETAINING NUT WILL NOT TIGHTEN.
IMPORTANT: METAL NUT (K) MAY SEEM TO BE TIGHT AND PLASTIC CONNECTOR (J) COULD BE LOOSE. CONTINUE TO TIGHTEN THE NUT UNTIL THE PLASTIC CONNECTOR WILL NOT MOVE.
E.) CLEAR ALL ERROR CODES ON THE TACHOMETER. REFER TO INSTRUCTIONS IN TM1402 OR TM1702.
NOTE: IF THE PROBLEM PERSISTS, THE FUEL TEMPERATURE SENSOR RE28217 MAY BE DEFECTIVE. CHECK RESISTANCE BETWEEN THE 2 PINS IN THE SENSOR. THE RESISTANCE SHOULD BE BETWEEN 600 - 15,000 OHMS. IF THE RESISTANCE IS OUTSIDE OF THIS RANGE, REPLACE THE FUEL TEMPERATURE SENSOR.
