Running a 4410 with almost 3000 hours on it. Has aim command, raven 460 for rate control and a viper pro for accuboom, autoboom, mapping and steering. Having issues with sections 1,2 and 3 shutting off this spring. It seems to work fine for the first part off the day then the 3 sections won't be spraying. On the viper today it. Would show 3 not painting and on 460 the 3rd light would be out. When you looked back all 3 sections wouldn't be spraying. But according to the viper an 460 1 and 2 should have been on. If I turned on sections 1,2 and 3 on with factory switches the would all work. Most of the times 2 wouldn't start until 1 or 3 were on. I've wiggled all wire harnesses and opened looms looking for broken wires at all pivot points. Tried 3 different master and slave aim command nodes. Checked all the fuses that I could find.
Today I was wondering about my accuboom node? Because as soon as I manually overode with the console switches booms would work again. So I was eliminating the broken wire theory with that thought.
But as of now even that has quit working. The only way I can get 1,2 or 3 to work is with my Spraytest remote control. Sections 4,5 and 6 haven't missed a beat all year. Things worked good last fall and sprayer sat in heated shop all winter.
Any thoughts or suggestions? A new accuboom node is $950. I was going to order one today but now with factory switches not working I'm at a loss again. Talked to dealer a few times and they really don't know either until they come look at it. And of course it's intermittent so it would probably work just fine if I do get them out.
Thanks for now.
Michael
Thanks for now.
Michael
