Have a Brandt 1545. Its been a fantastic auger. Only issues have been with 30hp Kohler but I think I have remedied that with a new 26.5 EFI Kohler. I really like the looks of the new Brandt 2045 conveyor, except the drive belt seems a little small for the job. I demoed a 10-20-55 Reliabelt this past fall and was pretty impressed. It was extremely fast; loaded 44T on super B in 9:45 and that includes moving between trailers. I was running this thing to max capacity and the belt moved so fast some lentils would fly over the tube near the intake and also some lentils would come back down the bottom of the tube from the top of the auger and pour out near the intake as well. I only ran it full blast but I think running it slower would have helped with those problems. The 40hp Kohler on this thing was awful. Extremely loud and very tough to get going, even in the warm weather. Hated the engine. The hopper seemed flimsier than the Brandt but cleaned out quite a bit better. It is almost a 2 man job running an auger of this speed to capacity; one guy at the truck and one guy at the bin. I would not run this auger anywhere near capacity if filling a drill tank.
I decided to go with a Reliabelt 10-20-90 with beaver tail and diesel motor so that I could use it for loading and unloading bins. I've had it for a month and its been nothing but trouble. Chews up hyd pump belts like crazy when using the lift control and main conveyor belt was too long from factory so dealer cut out 18" and re-spliced and yet it still wouldn't work, just slipped on drive roller even with the auger empty. They just put another couple springs on the slack eliminator so hoping that fixes the problem. My guess is the smooth drive roller doesn't provide enough traction in dusty product (like fertilizer) causing the slippage. The other mfg's use a piece of ribbed belting and I've never seen slippage of a properly tensioned drive roller on either a Brandt or Batco. The dealer has been busting his butt to try and get it working and that has been much appreciated. So far I'm very dissapointed in this extremely expensive auger after having had a good demo of a shorter unit.
