1 - 2 of 2 Posts
· Premium Member
When I switch on my solution tank agitator to mix dry products, my hydraulic flow struggles to keep up, the pump whines and pressure cannot keep up when moving machine. Sounds terrible. Everything runs fine when not agitating. I'm not sure where to start looking. Any ideas greatly appreciated.
I don't know how the 49xx works but on the 47xx and 48xx sprayers, agitation is nothing more than a valve that opens to allow solution to circulate through the agitation nozzles. It should not create any more demand of the pump and should have zero impact on hydraulics. The 49xx may be a different system but, if not, I would be looking for an electrical issue, perhaps when powering up the valve to open the current is jumping to something else causing the hydraulic system to work against itself somewhere.
1 - 2 of 2 Posts
