50 series combines with Tier 1 engines ( xxxxxx – 695500 )
9860STS, or 9880STS built before 2006 ( xxxxxx - 715000 )
9560STS built before 2007 ( xxxxxx - 720000 )
Any straw walker machine
The air scoop was designed only for large frame STS combines with 8.1L Tier 2 engines. The kit was not designed to retro-fit back to machines with Tier 1 engines, earlier 12.5L engines, or the small frame 9560STS because of possible air flow issues associated with those machines' cooling packages. Installing the air scoop on these combines may severely restrict air flow, resulting in engine over heating and a reduction in cooling performance.
Installation the air scoop on those machines is not recommended by Harvester Works. Customers should be strongly discouraged from installing the air scoop on:
Parts catalog information is unclear as to which parts to order for Tier 2 combines (695501 - xxxxxx). H216209 is ONLY the air scoop. You must also order AH220663 kit which contains the hardware, miscellaneous parts and H222387 instructions for installing the scoop.
Installation time is six hours.
Air scoops are standard on large frame STS combines MY 2006 ( 715001 - xxxxxx ) and on the 9560STS MY 2007 ( xxxxxx - 720001 )
