i am pretty sure he used to be the 2366 man, not 2588 man..
Yep it was 2366man buddy!
A 5088 has 5 more HP than a 2188, the only difference between it and a 2588 is just the HP they are 290 peak HP, the 2588 is 320 HP? not sure on that. If you want something that is the same as your 2588 you will want a 6088. The only difference between the two is that the 6088 has a 1/2in wider rotor drive belt and it UN-loads .5 bushel a second faster, holds 50 more bushel of grain
and a little more HP than the 5088.
Tell me if this helps your welcome to PM if you want.
Eric
