was told it could be alternator or ground cable. Heard of it before.
I believe it is 24v.
Mechanic is really suspicious of the circuit breaker between the batteries and the cab. I hope he is right!
Hi, did you find the problem? I have a 530 quadtrac with the same problem.I believe it is 24v.
We replaced the circuit breaker. Can't say that its fixed yet. Tractor is still in the shop for other work, maybe get it back in a couple of weeks.
I believe that is the starter relay. Doesn't look good. Are you having cranking issues?I think i found the problem. The circuit breaker looks bad... View attachment 167360 View attachment 167358 View attachment 167359 View attachment 167360
View attachment 167368 View attachment 167368 This is what the circuit breaker looks like
can you show me where it is? maybe this?it also looks bad..View attachment 167368 View attachment 167368 This is what the circuit breaker looks like
Looks like you need to clean a bunch of electrical connections. Will be a nightmare of broken bolts, etccan you show me where it is? maybe this?it also looks bad.. View attachment 167369
This is a 150 ampere bimetal cicuit breaker(“A Bimetal Circuit Breaker is a circuit protection device that is appropriate for low voltage applications. The active element of the breaker is a strip of 2 different metals bonded together, known as a bimetal strip. Under normal operation, the strip spans a distance between two contactors, completing the circuit.”)I replace it with a normal 150A fuse…Maybe even run without it?? I don't really see what purpose it serves. Everything in the cab has its own circuit breaker or fuse. Maybe if you drop a wrench on the hot post in the cab?
