have an electrical glitch in my 540c, several times over a hundred operating hours the unit shuts down completely. boom no warning, hit the key and it starts right back up! hope the computer has recorded a code or something. have no idea were to start looking. did the power connection tighten route and all was good. checked wiring harness and connectors they all were good.if it was a relay it would not start back up that quick.wish it would just die so we know the cause
check the screen above your reversing fan if that thing is loose it shuts her down. It usually gives an error code.
Discussion Starter #4
thanks S K farmer, touched the switch and the engine died. will tape a piece of metal over the switch and see if the problem goes away.
