Anyone else had trouble with the Iveco frying the rocker cover gasket alongside the turbo? Mine done it's 3rd in 3600hrs. The black rubber material can't handle the heat it would appear. Cheers
Case doesn’t use egr on most their engines.I would have to say egr isnt working right. Any idea what your exhaust temp is. Probably going to have bigger problems.
Partial throttle may be an issue, I rarely run at full noise. I haven't heard of this happening on the combines which obviously have +40 C ambient and 110% power.It happened to the owner of the larger model that I usually drive one night. I’m not exactly sure why. I cautioned him about lugging it too much and not to use partial throttle settings or to run it a gear too high. He had a fire but thankfully also enough Diet Coke to put it out. The new gasket was already in it when I pulled up in the morning.
I have thought of installing a big ceramic flooring tile or perhaps a second metal shield between that turbo and the valve cover but never did. By the end of this spring I should know if a less restrictive exhaust treatment system helps to prevent that possibility too.
It’s a -52 C wind chill out here this morning, -37 ambient. You would wonder sometimes how things can ever get too hot.
That’s the first thing to check always. The iveco doesn’t like to be lugged for a extended period of time but guys seems to think there saving fuel or wear.did you try putting in a new crankcase filter?
You mean the 12.9 FPT? Yes I had to change the rocker cover rubber last year. Thats on a T9.670 with the compound turbos. It was leaking when I bought it and I finally changed it after 2 years. We dont lug the engine so hopefully it will be fine for some time now.Anyone else had trouble with the Iveco frying the rocker cover gasket alongside the turbo? Mine done it's 3rd in 3600hrs. The black rubber material can't handle the heat it would appear. Cheers
