As title says my 590 went down today. looks like a twisted cylinder stub shft or bent web where the stub shaft attaches to. Cylinder has a notaciable twist in the rub bars. It doesn't vibrate at all under 700 but above that it's a shaker over 800 rpm. Thing is don't know when it got bent. Cart driver was coming up on my right side and since I don't have the cover on there he could see the multi v belt drive with the planetary wobbleing about a 1/2 inch. I think I know when it bent and it was in fabba beans a week ago. Went through a low area that had froze quite hard and the plants were still quite green. Plugged the impeller here. Since then all we have done was fabbas and canola so cylinder speed has never been much above 550. Rained here today so pick up a sunny rook cylinder and concave at the factory through Alberta harvest center. Looks like a 2 day job to do this but if it keeps raining think this is what i will do. This is looking like this is common in central Alberta this year with the tough conditions we are having. Tough straw and dry grain til now. All of our canola has been dry but plant mass has been damp where the stocks were on the ground.
Just looking for advice here. Finish what I have then change it. Once i take it apart I will probably find other things that should be changed. Could have to wait a extra day for parts. Thinking along the line that with 60 acres just finish with a wider concave opening and just nurse it along till done. What's your thoughts .
