Few days ago I was checking oil levels in the combine and noticed oil had been coming out of the gear case breather that’s bolted to the engine. Thought one of the pump seals had sprung a leak and was filling the box up. Drained the oil and measured what came out and it’s still the correct amount. Wat could cause the oil to push out of the breather albeit a small amount. The fan inside the pulls is kept clean and engine running normal temperature. Thanks
Discussion Starter #3
Around the main drive pulley dust was collecting on from the small amount of oil but by the breather it was clean from seeping oil.
