1 - 2 of 2 Posts
The 60 series reversers with the electro hydraulic reverser tend to quit working, because hydraulic oil leaks behind the cylinder, filling the cavity and therefore preventing the piston from moving. The update provides a drain hose for the cavity that contains the spring to push the piston back in.
Make sure you get this done, on our 06 9760 the feeder gearbox slamed into reverse after the electric clutch had fully engaged and blew a shaft on our corn head out.
Only down time we had with the machine this year.
1 - 2 of 2 Posts
