625F hyd problem
1055 Views 3 Replies 2 Participants Last post by  chicken wing
When I pressure up my 625F, left end locks out, but the right end does not.
I can push the right side down by hand. Checked all hoses and cylinders, no leaks. Any ideas?
How much pressure are you getting? Are you doing it at wide open throttle?
Pressure is good. Had it at high idle. The DR is at the left end 2850psi if I remember right. Looks like it is one circuit. My thinking is all cylinders should equal out, but they dont, from left to right they get weaker. Will look at the diagnostics
Ya it is all 1 line and the cylinders are T off it. The hose must be plugged or squished. Does the end cylinder even extend?
