Having issues with the header plowing dirt on left side. Underside of header is clean, everything is freshly calibrated, header has 200 hours on it. Cutter bar is not bent, cutter bar pressure is up at 1700. Crop divider is resting on ground but also had it slightly off ground. I've tried varying cutter bar pressure up and down. This is in lentils but had same issue in 320ac of peas I did. Sensor voltages are correct. Combine is an S670. The pictures were taken after 15 feet of combining. The fields here are as flat as can be. The header is not in float mode and is calibrated and setup in flex mode.
