1 - 9 of 9 Posts
Just fired up my old 6620 in some 6 row barley.
I seem to be getting too many beards in the tank. I know if I leave it another week it will help but its fine and dry now.
Cyl closed tight, speed 1100, top sieve fairly open, bottom closed down, fan about 700. Any suggestions. Thanks
That sounds like to high cylinder speed for barley. We ran an 8820 , and cylinder speed was usually anywhere from 700-800. Fan at 800-900 depending on yield or how full you could keep it. If not an airfoil chaffer, chaffer about 3/4 inch, bottom sieve about 1/4 inch or until you get the sample you like.
What condition is your concave and rasp bars ?As for cylinder speed,as long as you are not cracking seeds if it gets beards off thats what you want.Here in California dry land grain it hot and dry with low yields 1000 to 1200 rpms was common.Good luck getting it adjusted.
Im also having the same problem right now. I have tried the cyl speed at 600-1000 and closed the concave as much as possible. Looking at the filler plates, but seems like a huge job. Anyone know of a tutorial on how to pull the concave out? Top vs bottom mounted filler plates?? Need to harvest fast!!! Any suggestions?!
1 - 9 of 9 Posts
