I have a 6620 Hydrostatic. From time to time when I move from forward to reverse or reverse to forward or even to neutral I will get a hesitation and engine bog. It seems like a pressure build up. All belts are new and tight. Proper Low-vis fluid in system. The hydrostat works perfect otherwise. Is there a valve or valves that may be sticking causing this?
