You will have to swap off the plate that the fuel pump bolts too, this plate is what bolts the engine to the frame on the combine, and is flat. on the tractor it has bends in the plate to fit in the rails to hold the engine it is a little project to swap this off idler gear and the cam gear will have to be removed.
This is also the plate that the fuel pump bolts to. The tractor is going to be a Roosa Master, the combine could be Roosa Master or American Bosch depending on the year of the L3 pump mount is different. Not a big deal but you might have to change pump settings to match the combine. Everything else will be easy changes.
