I don't know if this will help.
Solution Number: 47385
Solution Summary: THE HEADER HEIGHT RESUME FEATURE DOES NOT WORK WITH A NON-JOHN DEERE HEADER - All 50, 60 and 70 Series Combines
Publication Date: Aug 6 2008
**Paper copies of solutions may not be the most current solutions**
Complaint or Symptom :
The header height resume feature does not work with a non-John Deere header, e.g. MacDon or Honeybee draper platform.
Problem or Situation :
The combine is programmed to recognize only John Deere headers.
Solution :
The header harness will have to be configured with a jumper wire as follows to allow the combine to recognize the header. The pin numbers and circuit codes listed below relate to the combine harness. There are two methods in which to accomplish this.
OPTION 1 : Install a jumper wire from CC436 (light green) pin # 16 to CC21 (red) (12 volts) pin # 4 in the header harness next to the connector. The only disadvantage to this method is that during diagnostic work with control unit E01 address 50, the type of header will not be identified. If identifying the type of header would be of value to the technician, then go with option 2.
OPTION 2 : Install one or more jumper wires as indicated below, in the header harness next to the connector. CC21 furnishes 12 volts power.
NON-JOHN DEERE DRAPER PLATFORM: CC436 (light green) pin # 16 to CC21 (red) and CC488 (yellow) pin # 17 to CC21 (red).
NON-JOHN DEERE PICKUP PLATFORM: CC487 (light green) pin # 28 to CC21 (red) , CC488 (yellow) pin # 17 to CC21 (red) and CC489 (orange) pin # 18 to CC21 (red).
NON-JOHN DEERE CUTTING PLATFORM: CC436 (light green) pin # 16 to CC21 (red).
NON-JOHN DEERE CORN HEAD: CC487 (light green) pin # 28 to CC21 (red).
Additional Information :
9770STS, 9570STS, 9560iSTS, 9650, 9560, 9550, 9550SH, 9660STS, 9860STS, 9560SH, 9670STS, 9650CTS, 9450, 9660WTS, 9750STS, 9760STS, 9650STS, 9870STS, 9660CTS, 9660, 9560STS
HEAD, WING, SWITCH, HIGH, CH, JDM ELEC, FH, PLAT, F5281, F5126, F5166
