I'm having trouble with moisture sensor stalling. I dropped down the grain tank loading auger took off the top plunger and cleaned every bit of debris from inside the plunger shaft. I put back together, turned on combine. Plunger will cycle three strokes and then the "plunger stalled" message will pop up in the command center.
I tried cycling the engine on and off several times. It always quits after the third stroke. By the way, the thing is not mechanically stalled, it will extend all the way and then quit. What the heck is going on??
