We have an early 7010 and in corn, that crappy little rubber flap seal malfunctions and results in a stream of corn dribbling out under the feeder house. The spring holder is staying in position but the flap still eventually comes out. It seems like the seal is made too narrow and when you lift to full height, it gets caught or corn pushes it from behind and doesn't slide back in right and it gets warped out of shape and eventually pops right out. I've heard of others having the same problem. Anyways, does anyone know if there is an update for it? If not, I'm thinking of making one out of some wider belting to see if it helps.
