somewhere on here in the past somebody posted a way to get the lights on the mirrors of a 7010 combine that shut off when you lower the header to stay on when the other lights are on and the head is lowered , Iwould like to know how that is done so I can make my lights stay on all the time
This is how I do it: take your turn signal lever on the left side of the steering column and make sure it is in the neutral position. Then very quickly lift it up and back to neutral. When I say lift it up I mean move it to the spot as if you were making a right hand turn (don't pull it towards you). And make sure all your other lights are on as well. This has worked on both 7010's and 7120's I've used.
On the 8010's those lights are hooked into the acre counter/ header height cut-in. Just set your acre counter cut in down to zero height. Just remember, the lights will stay on all the time and the acre counter will keep adding also!!!
