I have lost the ability to adjust the top sieve with the actuator. The assumption was the potentiometer had failled so I replaced actuator. No good. No response from in the cab or remotely at the back.
Both sieves run on the same fuse and the bottom is fine. Anyone had a similar problem?
Broken wire/plug or the relay is all I can think of.
Cheers
TH
Cheers
TH
