why the heck would I be looking at the glass when I adjusted it as per instructions in the operators manual? Turning a header around on 4 metre rotobucks there are plenty of other things to be looking at including the head ditch which you have to lift the front right up to clear.
I can clear 4 metre rotobucks with a mid-west without having to lift it right up. You're not the only one that cuts on flood irrigation old mate, you don't have to spell it out in great big letters
I just asked because the tilt gauge would have been right under your nose, but perhaps you needed all you had to turn it around at the end which is so hard going by the way you went to great depths to explain it...
The other thing I don't understand, in your first post you say "I had it tilted right back because of the corn head" then later on you say you "adjusted as per the operators manual"...
