Something is wierd with my moisture sensor on my new 740.
I have always felt the Quantimeter system leaves much to be desired in moisture logging in corn. It simply cycles so slowly!!!
It works perfect in beans. It would stay right on and not jump around more 2-3 tenths off what I know is accurate.
In corn sometimes it starts a pass and reads WAY low for 30-45 secs or several hundred yards... Like 8% or something. Then it jumps up to maybe 3-5 pts low and then 5-10 pts high and then settles in close to accurate.
It's either a problem with how it's taking a sample or in the software.
The field average is pretty close but my relative pass to pass data is worthless as the moisture is off so far it can swing the yield 30-40 bpa.
I have replaced the moisture sensor already and dealer is checking with Claas but I thought I would see if others are having issues and or a fix.
There is really no adjustment to make on the actual sampler on the clean grain elevator is there?
In the past I have had issues with the sampler sticking open and a bungee cord cured that. But every time I check its closed...
Been having to run manual moisture and shouldn't have to do this.
I really wish you could get a COMPLETE Ag leader kit on these 700 machines!!!
