What are you chopping? It is stress on the frame, or heavy load, or foreign objects. Mostly, in upper position this doesnt happen because front end leans against shearbar bed. When the bolt carries the load/stress, it can break. Drill the front holes bigger, so the floor rests on the shearbar bed. Also better for crop stream if its not in the way. Mostly happens in grass. Why upper position?
