Do you get a lot if splits at those higher cylinder speeds? What concave and cylinder do you have.Do you have the tm6 sieve? I have been running anywhere from 480-620 cylinder speed with concave from 13-18mm. Rotors 100 rpm faster than cylinder with covers closed mostly. Fan 1170 and 13-16 top and 5-7 bottom. The tm6 will alow more open settings and slightly higher wind. I'm running small grain.
Yes we get a few more splits but on the commercial non seed side but it doesn't really matter if we get 2-3% splits, there are no deductions for that at the elevator.Do you get a lot if splits at those higher cylinder speeds? What concave and cylinder do you have.
That is my biggest challenge with the 740 compared to axial flows.
Do you think the tm6 is as capable on hillsides with 3d for reducing grain loss?We don't run a long tooth but in beans, and every other crop other than corn, the tm6 is far superior. Much cleaner sample with way lower returns and slightly better losses. We have two with tm6 and one without. Next year all will have it.
Right in between.When doing soybeans are you running the cylinder in low or high range?
I'm not too sure about hillsides. It will reduce returns which should reduce sieve load so it should help. Our beans this year have been on fields that are flat enough the 3d sieve has been doing a good job.Do you think the tm6 is as capable on hillsides with 3d for reducing grain loss?
Maybe I will be reinstalling the tm6 during our rain delay.
