Its real simple. Remove your belts, remove the two speed. should have a dust cover on the center where you would remove the bolt, maybe nut on that one, get a cherry picker pull of two speed. Remove bolts and lock collor on cylinder bearing. Take a long a$$ prybar and stick under the cylinder with the feeder house full up. I use an air hammer and heel bar and pull off bearing. The key is keeping cylinder up when u pull bearing on and off.
