can someone please help me with my cart.I cant get the shaft rate to display on the monitor. It always says 0. I can get shaft rpm but no rate. any help would be great
product rate or rpm? You loose the ability to display shaft rpm when product rate is selected.
Depending on what has been selected to display, you may need to select the other function... can't have both unfortunately.
Do you have the manual?
Also check to see if you are getting a speed reading. I've had my sensor on the rear axle be out of alignment and it would show 0 for shaft rates. Check all the sensors to make sure they line up and are close to the sprockets.
