1 - 2 of 2 Posts
I have an 06 8010 and an 08 2162. I want to use the return to cut feature but when I lower the header to were I want to be cutting it goes automatically into the float mode. To solve this I have to unplug the header right now. I know it is the float optimizer on the header that is screwing things up. Is there something in the pro 600 I can disable so I don't have to unplug the header.
First do the "ground calibration" - header to the ground, push down button for cca 5 secs, hold up button till the header rises all the way up. Combine will recoignise how heavy the header is...
Than in the Pro 600, Toolbox, Head 2, Pressure float override set to at least 10%. I guess it should work now. If not, Toolbox, Head 2, Header pressure float. set it to NO and the float feture will B disabled
1 - 2 of 2 Posts
