1 - 10 of 10 Posts
How big is the 8010 hopper with the factory extensions folded out? Some say 330 bu., 350bu., and a case mech told me 330bu. without extensions and 400bu. with them folded out.
CaseIH did some "refiguring" in regards to grain tank capacity on their combines for 2007. The official grain tank capacity for an AFX8010 with factory extensions is 350 bushel.
Case-IH is now measuring the grain tanks using the same rules as John Deere and the rest of the manufacturers have been using for sometime now. The grain tank on an 07 is the same as the 04-06 models.
Quote:Case-IH is now measuring the grain tanks using the same rules as John Deere and the rest of the manufacturers have been using for sometime now. The grain tank on an 07 is the same as the 04-06 models.
I'm curious what exactly these rules are, and how there was a discrepancy earlier? Seems to me, you just harvest something until it starts to run over the hopper somewhere, unload that into a truck, and the grain elevator will tell you how many bushels it was. Maybe you have to figure in a standard moisture, so the grain doesn't stack up at a steeper angle, but still... I'm just curious.
-Lance
that must be about what they did on the 2500 series versus the 2300 when they refigured the unloading rate. What a bunch of BS.
The standard that CaseIH now uses for grain tank capacity is ISO 5687 Second edition. Not sure what the standard was before that.
As far as unloading rate on 2300 vs. 2500 combines, the unloader sprockets are different between the 2 machines, thus the higher capacity for 25xx series.
Lance- How it was explained to me was the old way they actually filled the grain tank and then measured the grain that came out thus taking into account the elevator,braces,augers and tubes inside the tank.
The ISO standard now used by CNH and has been by all other manufacturers for sometime now only uses the outside grain tank dimensions and they calculate the volume. This does not take into account for the elevator housing,auger/tubes, braces etc.
That is how they "found" another 20 bushels of grain tank capacity with no change in the grain tank. They are just using the same measuring stick.
Redhat, thanks for the specifics.
I base these thoughts on the idea that redhat's info is correct. So what is the point of all manufacturers having a consistently inaccurate (over-hyped) number? Seems the people who created the ISO "standard" were book smart, but have failed at real life.
Riddle of the day: If you put 350 bushels of 15% moisture corn into the hopper of an 8010, how many bushels will end up on the top of the cab? lol
-Lance
1 - 10 of 10 Posts
