1 - 1 of 1 Posts
SYMPTOMS- While separator is disengaged the rotor slowly turns in reverse direction, even while brake is applied.
REPAIR - Above the feeder cvt is the pumps for the rotor hydro and feeder hydro. Inner pump is the rotor hydro pump. Under the hydro pump for the rotor you will see a control valve with two solenoids. On this valve you will see a backing nut(9/16" wrench) with an adjustable screw(flathead screwdriver). Loosen this nut and very slowly turn screw until rotor stops. If it speeds up turn screw other way. Tighten up backing nut.
Automotive tire Hood Motor vehicle Automotive design Bumper
Automotive tire Motor vehicle Automotive fuel system Bumper Automotive exterior
7010 8010 7120 8120 9120
1 - 1 of 1 Posts
