1 - 2 of 2 Posts
Is anyone having problems with radiators plugging in wheat? In this area every 8010 not matter what year has problems. When harvest first started they were fine, towards the end after some showers and the wheat gets that black dust (don't know proper term). That fine dust gets in the cooler box. Case reps say it is an "area specific" problem, any one else in one of these areas? Hydro.
Don't think the problem is area specific either. The 7010 has a metal screen and the 8010 has a plastic screen made up of segments. The panel sections are held in with clips inside the rotary screen and the segments can come loose and a gap will open between the screen segment and the rotary air screen frame. The rotary screen frame will flex so if the rollers inside the assy are not adjusted properly to support the rotary screen it can cause gaps in the outer seal as well.
I think you will see the 8010 go to the metal style screen like a 7010. my $0.02
1 - 2 of 2 Posts
