Would you be scared of buying a 04 or 05 8010 if it has had all the factory updates done. What should one look for at 1000 sep hours? Is there a reason you can get an 04 or 05 for cheaper than a 2588, or are people just that stuck on a tried and true machine.
Not at all. As long as the original owner and their dealer have serviced it correctly and done the necessary updates it shouldn't be a problem. Normally the tailings processor unit will need rebuilding, the rear tray that lets straw run into the spreaders - the bushes either side will probably need replacing and the piece of pipe underneath where it rocks in and out will probably need building up. The grain elevator drive chains need replacing every season. Other than that probably just normal wear and tear on elevators, bars, in feed castings etc.
machine should be a 05 to have cone and cage updates, 04 machines can be done, has machine combined beans, what shape is feeder in, floor bent uo, feeder chains, what kind of crop will you harvest, smooth slat feeder chains, or sariated chains, other than that useual things that wear out, sieves check them out, are they bent, happens when its to easy to adjust from cab, crap gits inbetween seives and bendes them up and can be a pain, can you sit in cab and open and close top and bottom seives, if you can't actuators have been a problem and spendy, can you open and close concave, just some things to check out, you want the pro 600 monitor, heck of a machine, scott.
· Premium Member
needs to be certified all systems better check out cvt and hydralic systems elevators and feeder chains arn't anything to worry about on a 8010 CONTROL PRESSURE is. feeder chains all have problems on them. the new style cone and cage is a must
