I all, the auger in my moisture sensor of my 8120 isn't working.
- Tested relay and it's ok
- put 12V directly on auger motor and it turns
- 5 amp fuse is good
- Switched the little electric board and didn't change anything
- electronic eye light up when I put my finger on it
- I have power on the orange wire of the 6 pins connector that goes to the moisture sensor wiring. It's on even though rotor is engage or not.
I'm I suppose to have another wire with power in that connector? Rotor must be turning for the auger to work. Do the head have to turn as well?
Thanks for your help!
