new 09 in shop, improvements, finally single feeder chain, door latches, not them darn rods that won't let you into compartments, power disconnect at battery compartment, no brainer, new holland has had, should be in all equiptment, can open right hand rear compartment from engine bay to access radiator, hydralic driven radiator sceen, updated feeder, reverser, 420 hp, finally changed unloading auger so we don't seed all over ground, about time, changed elevator tighner system, shaft running thru housing so we can replace whats worn out instead of changing housing, pro 600 monitor got some changes, didn't have time to play, scott.
