Noticed today on our 8230 the rethresher is not far from falling off our harvester. The low shaft speed alarm has been sounding on and off a bit, couple times a day then nothing for a day or 2, monitoring the speed of it tho... i have been checking the shafts and bearings, today the alarm was very frequent in a 20min period, so was time to have a better look, also with the seperator on at half rpm, i notice a wobble in the whole rethresher assembly, all covered in dust...
any how found some cracking where it is bolted to the main frame as it enters the rotor area. Gave it a clean and the more we looked the more cracks we found.
Seems as tho the rethresher is fine in regards to bearings and shafts.
Something is making it shake and jump around, much more noticeable at full rpm. So bracing it and welding it is not going to fix the problem.
we first thought that it needs better bracing as the belt pulls on the whole thing with alot of leverage as pulley is up high. In the current state i think bracing will not fix the issue
Is it a common problem?
Maybe the shaker frame is out of wak causing some extra movement??
