The MFWD solenoid ( PART NO.RE211156)?is the solenoid closest to the right hand side at the rear of the transmission. On the left hand side of the trans is an identical solenoid which is used for the park brake.
First I would disconnect the rh solenoid and see if there is power with MFWD disengaged. If there is power I would then swap the solenoids to attempt to isolate failed solenoid. ( machine will not move from park if swapped solenoid Is faulty)
Best of luck
