Tractor worked fine all spring. Now it just won’t move. Goes into range and into gear. But nothing. Never made a noise before. Wasn’t under heavy load. Linkages move. Any ideas, what it could be?
Torque limiter can go out on them. It’s built into shaft between engine and trans. It is a shaft embedded in rubber inside a pipe. To check if that’s your problem you should be able to see chunks of rubber. Or failing that motor running have someone watch while you put it in gear and see if it is turning trans.
