So if a 9060 with a cummins is hard on fuel, what does a 960 have and how is it on fuel. Is there an after-market chip that would help a 9060?
They only used some cummins in 2007, some 2007 had the iveco. 960 all had the iveco. If your needs are between a 940 and 960, a cummins might do, if you have had the iveco you will not be happy. I wasn't.
on the Cummins, the engine serial number is an eight digit number, beginning with "4" and contains no letters or spaces. This number should be on a metal tag riveted onto the cylinder block, or embossed on the block, typically near to the water pump housing. Anything other than the above, is not a Cummins.
best regards
Marlon Khan
Ford Tractor Parts
The Iveco in the 9060 seems to hold on better under load than the cummins does. If you try to push the engine past 100% load the cummins will lose rpms sooner than the Iveco. The Iveco is better on fuel too in my opinion.
Model Year 2007 (SSN HAJ110001 - HAJ110516) machines are the only CR's with CDC engines. They were only in the CR9060 and CR 9040. The CR9070 and CR9080 have always had Iveco engines
I've got a 2005 CR960 with the Iveco. I don't have any hard numbers but it seems to use about the same amount of fuel as my TR99 but with a fair bit more capacity.
Just wondering if anyone has any experience chipping a 960 with the Iveco? Just not sure if really needs or could handle a 15-30% increase.
