When I warm the tractor up I engage the Airseeder fan and from new, sometimes the fan will take off in speed and you have to turn it off and engage the fan again and it will then be OK. last night after a days work it did it and you couldn't control it by adjusting the flow but when I turned the steering wheel it went back to normal. It then did it again
What is the cause of this as I'm thinking it may be just chuck it in altogether
Never thrown a code and fan is run on No. 4 SCV which is only used at seeding. Sometimes when you get out of the seat with it going the Hydraulic warning flashes on the post, but has never come on otherwise
Yeah that was my plan but it hasn't done it again.
I like using no. 4 because it's out of the way and not easy to accidently turn off.
Thanks
Related Threads
The Combine Forum
884K posts
52.5K members
Since 2005
