This is how we run case combines. I usually don't change left and right sides to be different. You could change slotted for large wire I suppose, but around here they come with slotted and works well in the separating side.
Row 1 - 4
Wheat
Hard thresh, small wire, slotted, slotted
Oats
Hard thresh, large wire, slotted, slotted
Barley
Small wire, large wire, slotted, slotted
Canola
Small wire, small wire, hard thresh, small wire
For canola, we find that all 4 rows to be small wire to be most efficient on most years. However it changes so much. I use the hard thresh as a small wire concave in the separating area. You want to keep straw and pods as much as possible through the rotor and not drop them onto sieves, this increases capacity and not overload the sieves so much. There is a fine line here as well, can't over thresh so fast rotor speed and tighter concave setting to get crop through quickly is a must.
Other things you should be getting. Chopper cover plate. Its a cover plate that goes over a grate just before chopper. Get the kit and never take it out, unless you plan on doing 200 bushel corn. Manual residue deflector kit, goes behind rotor, helps even the straw and chaff from building up on right side.
Also check out this site, it's NOT official case site but it has a lot of god info from someone that really knows what hes doing.
Harvesting Tips | Case IH Harvesting
