06 936D right draper stops turning when you get into a heavy crop or lots of straw. Replaced all the roller bearings and the draper is tightened like the manual says. There is no build-up inside the draper either. Could the drive motor be getting weak? The speed of the draper seems fine. I have no trouble with the left draper.
had a mate had same problem 2 years ago only on the left belt, turned out the belt was sliping on the roller, the only way he could fix it , he got some non slip tape from jd dealer put it round the roller, instant fix , hope this helps
another thing that may cause this is the platform adapter to rear frame height adjustment been too low, basically spring height. Check LHS and RHS of main adapter and place ruler across and it should line up approx 4 1/2 to 5 " from memory from top. There should be two dots to line up. If this is too low the side belts jam on the centre belt skid plate side rubbers.
Could also be main draper hydraulic pump on way out also. The RHS belt is last in circuit and normal 1st to stop working if on way out.
