My 936 Deere draper at just over 300hrs has started leaking out draper drive motor seals. Not sure if it was the heat, straw and dirt buildup? Is there any updates since this discovery? Another local cutter had the same problem on his and he kept changing seals. I know these are just eaton motors with surprisingly eaton tags on them, Deeres usually not so nice about this kind of info. Has anyone else had this problem and found a remedy other than replacing the whole mess? THanks guys.
