Hello everyone!
I have a 9370 Case Ih tractor with standard transmission. I am trying to determine if I have the high flow hydraulic option. I have all the features indicating that i DO have the high flow option. Like, dual filters on the right side frame rail (one filter is smaller than the other filter). and A smaller hyd. hose going to the side of the valve body. What is throwing me off is, we have a 9180 tractor and it looks like it has the same size hyd pump. The 9180 we have does not have dual filters (only a single filter on the RH frame rail) and no small hyd line going to the side of the valve body. How many GPM does the high flow option have on the 9370? Will I be able to run a Precision 800 Drill with a variable rate cart?
Thanks
Discussion Starter #3
160853
This is the main pump on the front of the transmission. There is also a pump on the back of the transmission. I have read that the main pump runs remote 1 and 2 and the back pump powers the steering and remote 3 and 4?
