It'll be a problem with the control valve on the lower left side of the frame. Check for 12 volts at the 2 pin connector going to the solenoid on the valve and check if the solenoid is magnetizing by touching something steel to the end when it's powered. The key switch will need to be on to check this. You should hear a faint click at the solenoid if all is working properly. Often the 2 pin connector just needs to be cleaned
