Hi I am from Chile, South America and sometimesI have problems with the engine speed at low speed varies between 900 and 1150 rpm, when this happens and stop the engine, starting again immediately, it is a problem, however I hope this cold part immediately, replace all filters and the problem continues.
I hope you can help me.
· Premium Member
Hi trillagro.
Does the problem also happen at high rpm, or only at idle? Does it happen with a full tank or empty tank? I've heard of 9600's with blocks at a strainer inside the tank outlet.
Check for fuel flow from the filter below the tank, and check the breather to make sure it isn't blocked.
Good luck!
Hi, Olescool check the sensor and sees everything in shape, ran the combine today for an hour and no fault at all but only work at low rpm (1210), now in Chile it is winter so only work under shed.
