My 9500 combine will not lift the header while the engine
is on low idle and while it will lift it on high idle it just seems
it's not as fast as it use to be.
So i called my JD man and he said it was either a bad
poppet or relive valve gone bad. So i changed all of that
It was also leaking down to but the parts i put in to day
fixed that but not the lift speed.
I also put in the things that the coils move back and
forth can't remember what there called.
So i called my JD man again he said check the pump
pressure . Went and my Buddy's hyd test gauge kit
and it tested fine.
So what is the problem.
and it tested fine.
