replaced RH bearing and collar on primary countershaft because collar had broken away approx 300 separator hours ago. Just finished harvest and noticed collar broken away again! Anybody have any idea on what would cause this? Not happy, big job!!
I always thought bearing locking collars are tightened in the opposite direction of shaft rotation.Always tighten bearing locks in the direction of shaft rotation...or they can work loose and crack as indicated.
Shaft could be spindled/worn too small where the bearing sits like mentioned above.
They started that design with the 9000 series in '89. I would say that the tube style would be stronger and not go out of true as easy with a larger diameter. No doubt Deere was gearing up for more horsepower/torque with the 10/50 series and needed a better design seeing that 20 series needed those bearings done every 1500 hours.When/why did Deere go to a 3 piece shaft/tube design? The 8820 was a solid shaft. Still have about 3/4 of one left on the scrap pile.
Andrew
Nope, that's the direction you turn them to release them. Though more than once I've seen them done backwards, so you are not aloneI always thought bearing locking collars are tightened in the opposite direction of shaft rotation.
