I have a customer that uses this tractor as a packing tractor. The two bottom bolts on the final drive have snapped off. Has anyone else seen this or know what causes it. I don't want to drop the axle and take apart the final to extract the bolts and have it happen again.
Can you drill them and get an easy out in there? IME, most cap screws with the head broken off unscrew fairly easily. If at all possible, get someone with a lathe to make a sleeve to go in the hole to hold your bit centered. A head on the sleeve will allow you to easily move it from hole to hole. Drill the stud to 1/2 screw size.
My guess is the screw is broken where the unthreaded shank transitions into the threaded area.
