1 - 10 of 10 Posts
Have you had the rotor bearing updated from the original bearing... They updated this in the factory so it may not be an issue..
If the motor is not lugging down you variable speed pullies spring tension is bad..
Had this problem on a new Holland. The large main spring in the pulley needs to be loaded,
Also check your feed cylinder in front of the rotor... Those belts might be slipping causing slug feeding...
Found the rotor slipping problem. Seals in rotor drive shive bad and leaking on belt. Did not notice leak at first but it got bad enough to be dripping out of shive. Thanks for the help. Does anyone no the part number for the flapper that goes between the chaffer and the open chopper door. Am having trouble with it leaving streaks of material falling between the door and chaffer in soybeans
1 - 10 of 10 Posts
